JamesBall
Although the rear electric adjustment of the drivers seat was working perfectly when I picked the car up, I managed to break it on the way home! The right-hand rear piston (as you sit in the seat) only retracts a couple of mm before sticking while the left-hand rear piston retracts all the way, although accompanied with much noise, grinding of gears etc.
There is clearly power to the rear right hand piston as it moves a little. Is there a common fault which causes these to stick? Putting weight on it while lowering the seat doesn't help, by the way?
And is there a way of manually lowering the seat? At the moment my head is jammed against the roof of the car!
(The front pistons have power to them but neither rise nor fall - perhaps the same issue as had befallen the rear right piston?)
