ukmastiff
Sorry but this wont be short.
Today my car went on a rolling road. The man did his pre checks and his companion , listened to my engine through a stethoscope to rule out any pinking. As they ramped things up still listening etc ( pre power run) the car showed massive overfuelling. I was told to expect up to 3000 ( of what ever it is parts per blah blah in the exhaust) but it was rocketing to over 12 or 14,000 basically off the scale. At one point when pushed the car started to completely cut out.
Now the reason I know this is genuine is that on the 944 run a couple of months ago , my car did this if I really flawed the accelerator , and I did mention it to Paul Mc n or Jon , I cant remember which. However the car has never done it since and I put it down to bad fuel or something.
Now I know of course that the car was overfuelling and cutting out.
So even though I only went for a rolling road session with a view to having the car
'Pro Maxed' and then going on the same rolling road again , I now have a problem .
I now know I have a sick car. The garage tested the fuel pressure regulator and tell me that is working fine. They then tried to tweek the setting inside the top of the AFM gradually backing it oiff the spring. Now I hve taken the car back but it is doing it worse than when the car went in. I am not taking it back there as clearly I only went to them for rolling road in the first place and I want a specialist to tell me whats wrong not someone else to fiddle for hours ( at my cost) and not even fix it ( or make it worse as has happened here) The man with the rolling road has suggested it may be the wrong AFM ? , I think if anything more likely the /AFM is up the duff.
Obvious question is does anyone have any idea what would cause this overfuelling problem as I clearly need help. To be clear if you wack your foot down the car will completely shut itself off until you lift your foot especially over 70 MPH and the best way to drive the car is gently tickle the accelerator. This is now worse since he tampered with the AFM though he marked its position and put it back ( alledgedly).
Regards Mas
Regards Mas
