Master Cylinder Help
Kongsodoken
I'm looking to buy a new master cylinder but all the ones for sale seem to have 3 outlets
mine being a ABS car only need 2,
Do I just block the extra outlet up?
this has the correct part number but still 3 outlets
http://www.amazon.co.uk/ATE-03-2023-0542-3-Master-Cylinder-brakes/dp/B00404XNOM
Looking at PET, it looks like the third hole (Rear left) has a bleed nipple fitted. They call it a "ventilation valve" but they also call the bleed nipples on the 4-pot calipers that, and they have the same part number.
Update: I just looked on my car, and indeed it only has 2 holes. The casting is shaped for the third hole, but not drilled. I guess some of the original equipment ones saved money by not drilling the un-needed extra hole, but the replacement market ones have all 3 drilled and you just block the one you don't need.
ORIGINAL: sr.944man
Thanks I'll give it ago,
i think i will order the venttilation valuve to block it off so it looks right
