mayo in the oil filler neck...
- Thread starter Guest
sawood12
Neil Haughey
As a side note I had a head gasket on a SAAB years ago that had slight blow on one cylinder. I didn't check the plugs, then it got worse, couldn't extract one of the plugs and the one on the next cylinder was destroyed (head fell off). The blown gasket caused the head to overheat cracking it and effectively making the cylinder head bin fodder.
George Elliott
I follow your theory Scott, but my A4 has a sump and a 4 cyl turbo engine but never does this, none of my previous mainly VAG 1.8 or 2.2 five cyl cars ever did it.
Do all 944's do it, or just most of them?? Is it after a certain mileage?
What is the cause? what is different to "any other" engine which I would regard as clapped if I saw this moisture/mayo in the filler neck.
My suspicion is that it is related to vastly poorer than average piston / bore sealing and a larger % of compression leakage than a "normal engine". (My 944T compression is 130psi per cyl +/- 1psi) Been the same for 30k miles.
I just ignore it.[8|]
But I am curious as to the reason why it is so common.
George
944T
Justin85
http://i2.photobucket.com/albums/y25/dirtyflare/Mayonnaise.jpg
This water vapour comes from blow-by gases - the combustion mixture and its combustion products which get past the piston rings into the crank case. Water is one of the main products of burning hydrocarbon fuels, the other being carbon dioxide, so these gases contain a high proportion of water vapour. In cold weather and on short journeys, and on certain designs of breather/filler, the oil and water vapours condense where it meets cold surfaces such as the breather pipework.
HTH.
Justin.
But as the others have said, it's most likely just condensation.
Diver944
ORIGINAL: George Elliott
If conditions and useage are right then I believe that all will do it.
The filler neck is uncommonly long on a 944 engine, is on the opposite side to the hot exhaust and is probably one of the coolest places in the engine bay so condensation will naturally form there.
My new engine with only 4000 miles on it is effectively blueprinted due to SimonPs obsessive attention to tolerances and it has a nice film of mayo on it's filler cap right now.
George Elliott
I will continue to ignore it.
George
