Hi guys
I am new to Porsche ownership, i am now the proud owner of a 944 S2.
Couple of problems though:-
1. The gear stick is very slack, lots of play, in neutral (or indeed any other gear) there is at least 3" play either side. I was advised that both sets of gear box bushes need replacing. After inspection (local mechanic) these are ok. Is this a common problem?
2. There is a noise - sounds like the rear near side wheel bearing but these were both replaced only 5000 miles ago!? Same mechanic advises that there is nothing wrong with the bearing, but potentially could be a problem with the gear box (both problems could be linked).........GULP!
Anyone have any advise / experience of a similar problem? Or does anyone have any idea where i could get a second opinion (local to Cambridge)?
Dan (desparate)
Dan (desparate)
