Hi all,
Newish to the Porsche Club and looking for a garage who's good with brakes. I had the callipers replaced my 1989 944 Turbo (M030 spec) and there's a knocking sound when you initially reply the brakes after changing direction; the garage seems to think my original brake pads are slightly too small for the new callipers hence the slight knocking sound. The supplier I sourced the callipers from says there's only one type of Brembo calliper fitted to the 944 so I'm stuck between the mechanic and the supplier as to what's correct. The garage also said my old ones look "too corroded" to refurbish which would have been my preference. New callipers from Porsche area around £800 each side! There's also a brake pad light illuminated which was intermittent and the garage said it was cabling as the pads have lots of material on; following their last lot of work, the light is now on constantly.
1). I'm in the Sevenoaks, Kent area and have tried La Rose, Paragon (no success) and a couple other local places, can any of you recommend someone who can provide some expertise on the brakes?
2). There's an "86" stamped near the 20.4873.00 part number, could that be from a 1986 car and hence the issue with my 1989 car?
Any help greatly appreciated
