michelin cup tyre pressures
- Thread starter silver7
PhilRS
Road pressures are as Vic said.
ORIGINAL: silver7
Hi,
Has anyone run michelin cups on a 993 rs, any advice on pressures compared to toyos would be appreciated as i have just purchased a set.
thanks in advance
paul howells
For track use dry 31 all round hot pressure,36 may be ok for the road.
34 for wet track.
Richard Dawson
The upside is they are cheap and grippy.
Used a pair of new rears last Monday , in the dry they moved around , ' cos of extra thick when new , when it rained, i had the last laugh! They re going to last at least twice as long, believe u get 6mm when new ,be terrific in rain........i give up some dry grip to Cups ...............have been known to drop a couple of extra pounds down when new ish ,grip improves
Richard Dawson
Are the 245 better? In faster corners seems well balanced on 235 with current set up.
paul howells
Standard sizes are fine ,a standard 993 /rs does not need to be over tyred.
A good combo is 285 and 235 for track days but worse on the road for following white lines and uneven surfaces etc,bigger the front tyre the less turn in response you have.
Toyos are ok for the money,they do overheat quickly but are a great winter/wet tyre.But they are no where near the quality and consistancy of grip of the Mich cup.
The dunlop and Kuhmo tyres are also very good,better price than the mich and a little more expensive than the toyo, with a good wear rate.
Kuhmo,s need to purchased early in the year to get the differant compounds and sizes etc,most speed champs boys use them to great effect.For track days a Hard rear and med front is fine,and work well in the wet.
The idea of even pressures is to try and get a balanced platform including side walls of the tyre/contact patch.For hillclimbing i used to play around with lower front pressure for a bit more mechanical grip/less understeer,but this was very often in slow corners and in wet/slipprery conditions.Seemed to work well.
The most important part for any sizes of tyres is a correct set up,which can maximise grip and reduce unwanted heat and roll over etc
