michelin cups or toyo r888???
- Thread starter rs phil
MarkK
Toyos are cheaper though.If you use your car more in the summer and want no compromise get cups,if you venture out alot when there are odds it could be wetter get the 888s..?
Big Dave
ORIGINAL: jason
Have to say that by far the stickiest and best cornering tyres I saw were by 2 cars both wearing the same rubber at Oulton last year - and they were both on Dunlop DZ03G and swear by them.
I'd be considering those also....!
I second the Dunlop tyres. Ive used the previous tyre the D01J for a good 2 years + find they are one of THE best tyres around...
Not keen on the Michelins, they "go off" ie overheat when pushed hard...+ i suspect the Toyo 888,s do the same as they are a soft rubber...
The Dunlops are a VERY predictable tyre...
paul howells
Dunlops overheat quicker and go off before mich cups.
Khumo are also very good,dry or wet,nothing like as noisy at toyo or dunlops.
On the 993rs we run dunlop 265 and 235 18,and khumo 285 and 225 18
Which Khumos did you run, I had a look around and couldnt work it out.
paul howells
You can get a hard compound rear and med front,works well.
For sprints and hillclimbs med works well allround
ORIGINAL: Ian964
I've just looked for the Dunlops - the right sizes are available (from Camskill), but they're a lot more expensive than the Toyos. £900 deliverd for 4 compared to £600 for the R888s in the same sizes (from tyretraders, where I got my last set)
Ian,
Have you tried Mr Tyre Motorsport who are the main UK supplier for the Dunlops ?
http://www.mrtyremotorsport.co.uk/
I used to get my SSRs from them, and they were cheaper than anyone else .....
Jamie
Mr Tyre Motorsport will do the DZ03Gs for .....
255/40/17 @ £229 + VAT each
225/45/17 @ £125 + VAT each
Delivery £14.95
So, all in for 4 tyres I make that £829.15 - better than Camskills but still a lot more than the R888s
Jamie
