pae
Just back from the Sussex Summer event, excellent weather and a great turnout (except 924's, only 3 of us that I could find - one of each, a Turbo, a 2.0 and my 'S'.)
So, having seen all those immaculate cars in the concours I thought I'd pull the door mirrors apart to prepare them for a much-needed re-paint. The manual makes it sound so easy.....
Now, I'm fiddling about in the hole in the base for what seems like eternity and nothing is coming apart. So I take off the mirror to have a look up inside the hole but still can't see this locking ring thingy. What am I looking for exactly?
For a start there is a hole in the metal mirror housing and a hole in the plastic front bit. I'm guessing it's the one in the metal housing? And how far should I insert the screwdriver to engage in the locking ring tabs? On the drivers side there doesn't seem to be anything obvious to engage with, just a lot of pretty solid metal lumps inside, none of which feel like they want to turn. And what way is 'counter-clockwise' as it doesn't say in the manual which way you shuold be facing?
(BTW - the hole on the drivers side mirror is larger than on the passenger side - is that relevant?)
I fiddled about for ages and nothing seemed to be happening on either side. Is it obvious when you've released the locking ring? Does it simply fall apart at that point?
It's probably blindingly obvious when you've done it once and seen the bits, but I haven't, yet....
So, I've gave up on that until you good folks give me some pointers, and turned my attention to the sunroof - you'll have to wait for that post to follow as that wasn't a very spectacular result either. Believe me it's not been a very productive afternoon.
thanks in advance............ Phil
