Misfire and Smell of Sulphur
Hugh Ross
Hi All
Long time, no post (last post resulted in Richard H advice to replace radiator cap at £10 when OPC wanted to fit new radiators as an £800 'precaution'.)
Have had occasional misfire of late, usually when cold but gone when warm which I put down to lay up over winter/lack of use.
Misfire became permanent at the weekend, emissions light flashing and now on permanently and strongish smell of sulphur in the car after a few minutes of this.
Was only a mile from home so got back on light throttle.
Any thoughts?
Will get to an indy on a trailer to have checked out but any thoughts appreciated.
Hugh
ORIGINAL: Hugh Ross
Hi All
Any thoughts?
Hugh
I don't know too much about 996s but it sounds like a catalytic converter issue to me. They tend to break down over time and create clogging or back-pressure problems. I'm sure a kettle owner will be able to help in more detail.
Could be coil packs. A misfire/lack of spark could be putting unburnt fuel into the cats.
Best get it checked out pronto.
Thanks Richard, are coil packs an engine out replacement?
Don't intend to run it at all until diagnosed/sorted, I was very close to home when it couldn't clear itself - will keep you posted.
I would also support Richards statement. Had my coils replaced as part of my service. I'm not aware that they took the engine out. Approx £35 per coil at an indie.
Good luck
No, it can be done easily without. You have to take them off to change the spark plugs, so it is a regular service item. Unless it's a Turbo, in which case it's a marathon.
