Before I book my car in for its annual service, has anyone else suffered the same problem, and shed some light on the likely scale of my 1999 3.4 C2's fault?
In first and second, I am able to accelerate up to the rev limiter smoothly, unless pointing up a steep road, or anything less than flat throttle. In third and above the engine simply stops accelerating at around 5750, crawls up to about 6000-ish and then seems to clear itself. At 140 in top, it refuses to go any quicker, and you must change down and try and creep through (obviously, I need to do this regulalrly in South London, which is why I have left it for months to sort out!) The load on the engine is clearly a factor, I reckon.
Could be a plug, lead or coil, I guess.
Any clues, please?
Any clues, please?
