Hi I tried this question in the general discussion area the other day and got no response so I thought I try in the turbo list.
problem is :- Car starts fine hot or cold, when cold runs quite smooth I think there is just a VERY slight miss (but pos not) as it warms up miss develops still drives ok just a little down on power (as you'd expect).
I 've swapped the leads , changed the fuel filter and rear pump, dissy cap and rotor arm look good and not very old (I've only had the car for about 6k miles)I've ordered new plugs should be in today. Some one has suggested perhaps the warm up regulator but they say I need gauges to check this is there a way of doing a test without the gauges?
Pleaes help has anyone got any ideas?c os its driving me wild!!!!!!!
by the way its a 1987 3.3turbo with 100 k on the clock [][][]
