Mixture adjustment advice please
- Thread starter audicdl
Steve Murley
Just to check, you are thinking off the adjustment screw on the underside of the air flow meter, which is the mixture
screw,
The other screw, on the throttle body, above the idle valve, which is more visible, is for the idle speed, this sometimes gets mistaken for the mixture screw.
[FONT=arial, arial, helvetica"]FQS Table #5
[FONT=arial, arial, helvetica"] [FONT=911 porscha"]PORSCHE 911
[FONT=arial, arial, helvetica"]Switch Position
[FONT=arial, arial, helvetica"]fuel mixture
[FONT=arial, arial, helvetica"]ignition timing
[FONT=arial, arial, helvetica"]0 stock
[FONT=arial, arial, helvetica"]0%
[FONT=arial, arial, helvetica"]0°
[FONT=arial, arial, helvetica"]1
[FONT=arial, arial, helvetica"]+3.1%
[FONT=arial, arial, helvetica"]2
[FONT=arial, arial, helvetica"]+6.3%
[FONT=arial, arial, helvetica"]3
[FONT=arial, arial, helvetica"]-3.9%
[FONT=arial, arial, helvetica"]4
[FONT=arial, arial, helvetica"]-2.79°
[FONT=arial, arial, helvetica"]5
[FONT=arial, arial, helvetica"]6
[FONT=arial, arial, helvetica"]7
But on the motronic cars, the FQS switch is used to set the mixture is it not. The above table was taken from http://frwilk.com/944dme/fqswitch.htm
