Mking caliper brake pipes for a '84 944
Paul Fraser
I've been told by the OPC that the short caliper brake pipe that goes between the caliper and the brake hose is no longer available from. Anyone any experience of making their own brake pipe bits?
Any good garage workshop should have the equipment and be able to fabricate a pipe for you. I'm surprised your OPC wasn't more helpful.
Failing that, the equipment isn't that expensive. I kitted myself out to do the pipes on my Westfield. It is quite satisfying to make up a pipe that goes exactly where you want it to (even more so if it doesn't leak [;)]).
Alternativly, most motor factors sell made up pipes, you need to tell them how long and what unions are fitted
Dave
Ok then, anyone know what unions are on the caliper brake pipe for a 84 944. Also, how long is the pipe, any particular shape (I'd _readlly_ appreciate a pic with a ruler alongside).
Who sells brakeline manufacturing kits? Thanks.
