jac in a box
...No, not my nearest and dearest! Something iffy going on with the car. NoTiced a slight whining that wasn't present a few weeks ago. Noise has got progressively louder but I can't pinpoint where it's coming from.
Didn't usually didin't hear it until 50'ish now it's louder and present from around 10mph Noise seems to be related to road speed.
Suspected wheel bearing but I can't feel any play or detect any roughness when rotating the wheels with car on a jack.
Starting to think it might be gearbox / diff related (Tip box) - noise changes pitch depending on whether engine is under load - not on load. Had it been wheel bearing I'd have expected no change in pitch.
Local OPC thinks it's a tyre problem. They're at correct pressure and still have a reasonable amount of tread. I've also swapped wheels with a spare set and noise is still evident.
Nothing caught in brakes/discs/backplates etc.
Obviously an OPC visit is on the cards and the warranty will hopefully cover the repairs (wheel bearings covered under extended warranty?)...anyone any other thoughts?
Thanks, Dave
Thanks, Dave
