moisture/condensation under rear trunk.
- Thread starter Sylvian
If the rubber seal in the cap allows water under pressure to escape there is nowhere for it to vent as the rubber seal around the coolant/oil filler area traps it, obviously the luggage compartment lid is cooler so the hot moisture will condense on the boot lid
BartyB
My theory is that if the cap and reservoir are OK and there's no drop in coolant level, then this condensation is due to air being trapped in the space which gets heated and the moisture it carries condenses out on the lid. Just my £0.02 worth.
notechmike
