tim_haskins
Hi guys,
Whilst looking at the very slight oil leak on one of the engine oil pipes I have noticed that there is a transmission oil leak comming from the output shaft seal on the gearbox. I may as well change this as well!!!.
Anyway the job looks fairly easy to do am I right in thinking that you have to undo the drive shaft allen bolts. Then undo the drive shaft mounting flange (it looks like on PET that it is held in with 1 bolt through the center).Then just pull out the carrier to get to the oil seal.
Any advice welcomed on this. I will of course have to drain the g/box oil and I will make up a tool to fit the new seal on the lathe.
Also whilst on the oil leak subject has anyone replaced this oil pipe on their 964. Part number 964 207 257 11.
Are there any issues with doing this ie oil pump, it looks awarkard to do but it does look possible!! unlike the rear tinware behind the Power steering pump which to me is impossible to change without dropping the engine! Maybe one for the winter.[]
Thanks for the help
Tim
Thanks for the help
Tim
