robbosliding
In the ongoing search for the perfect tyre pressures (32psi rear and 28 front is looking good) I have checked the wear on the front of my C4S today and found the following wear tendancy.
The tyres are worn symetrically- the wear is from the inside of the tyre evening out across the breadth of the tyre, ie it is near the wear indicator on the inner part of the tread and the wear reduces across the face of the tyre.
Is this characteristic of correct tyre wear on the front of a 911 or is the tracking/geomerty questionable......?
I have it in my mind that it is probably as it should be, does anyone want to rain on my parade?
