944cabby
A short while ago i replaced the plastic elbow that connects to the waterpump as it was leaking water.
It now appears to be leaking from the underside of the large rubber hose on the opposite side to the elbow - and using a small telescopic mirror i could see water on the underside of the pump just in front of the hose and jubilee clip.
Now yesterday i used the car most of the day and when i parked her up i placed some card underneath the pump/hoses etc to help trace the leak (it's sufficient to be noticed on the floor after the car is reversed out of the garage).
If you look at the pic the black line was directly inline with the rad fans.
Could anyone hazard a guess as to where the other two water leaks could be coming from - pump gasket?
I can't see any other leaks from hoses other than the one mentioned so i'm thinking it's the pump.
