Morning all - Boxster 981 P1433 Cooling System Fault (Yellow)
- Thread starter Wilbur
I have had this light appear twice on my car.
The first time it was one of the change over valves which had failed. The second time 8 months later the light came on again and I thought it was another valve but turned out to be the brake vacuum booster pump.
Hope this helps
Tracy
AndrewCS
Wilbur said:Thank Tracy.
I looked in the engine bay and traced a pipe to the exhaust , I reconnected the tube to the PSE Sports exhaust and cleared the code. It's not come on yet.
No idea why an exhaust would trigger that code, so it maybe not be related.
I had the same issue albeit I did not read the code ... the vacuum tube had sheared off the nearside PSE actuator. Advice from this Forum was that ... the cooling system has vacuum operated valves and `any` vacuum system fault is identified via the cooling system alarms.
