MOT pass
alwigley
Nice new MOT certificate as of this morning - slight leak from exhaust, and new tailpipe rubber support easily fixed [:)] Now to figure out where the oil leak at the front of the engine is coming from [:mad:] Amazed at how clean she runs - emissions were a fraction of the limit......
Nice when they sail through like that! Oil is the bane of my life at the moment, having spent the thick end of £500 to get one leak sorted, I have found that it masked another leak.... I keep getting clouds of oil smoke from a leak dripping into my exhaust, I found it coming from my cam cover so had the gasket changed when it was in for it's MoT/Service, of course it is not advisable to re-tension an existing cam belt, so having had it done last year, I opted to have a new one, and oh, would sir like a new water pump whilst we are at it? Got the car back and whilst the rate of smoke is much reduced, I know think I have a leak from my head gasket...which could be an altogether much more expensive caper to fix.... I have to balance the cost of having it done against the risk of my head gasket getting worse and affecting the water/oil mix (it won't get any better!), the embaressment/smell of smoke pouring from under the bonnet in traffic jams and the small cost of keeping the oil topped up.....
ORIGINAL: Fat Albert I keep getting clouds of oil smoke from a leak dripping into my exhaust, I found it coming from my cam cover so had the gasket changed when it was in for it's MoT/Service, of course it is not advisable to re-tension an existing cam belt, so having had it done last year, I opted to have a new one, and oh, would sir like a new water pump whilst we are at it? Got the car back and whilst the rate of smoke is much reduced, I know think I have a leak from my head gasket...which could be an altogether much more expensive caper to fix....
So another new cambelt will be fitted when the head gasket is done ?, not sure I understand why a recent cambelt can't be correctly re-tensioned. It's your money and up to you how you spend it but there does come a point when maybe a better car would cost less in the long run.
ORIGINAL: Fat Albert No, the new cambelt needs re-tensioning at 1500 miles, so I will have the work done co-incident with that
Makes sense, wasn't a dig at you just wondering what TWG had advised, as for the better car comment that's just my opinion, if a car has a succesion of issues I lose all enthusiasm for it and usually change it.
The difference in cost between having the original cambelt taken off and put back on to change my cam-cover gasket versus having a new one put on was only about £80-100, the Water pump was an extra £200. I can't sell it in it's current condition, I need to get this issue and a murmuring bearing done...at that point it will be a fantastic car and I will want to keep it!! One of the previous owners, about 5 years ago, had a succession of 4 bills each between £2000-2800, so I think that less than half the car is 22 years old....
ORIGINAL: Fat Albert One of the previous owners, about 5 years ago, had a succession of 4 bills each between £2000-2800, so I think that less than half the car is 22 years old....
Worth renewing the other half then.
