morris944s2john
Nearly all my own work too, and what a lot of work needed this time:-
All four callipers stripped, cleaned and painted (to stop plate lift)
New front disks (fronts worn and corroded)
New front ARB bushes (no clonking front end and tight cornering now!)
Rusty sills repaired (plates fabricated and butt welded in- left sill needed 5 pieces fabricating, all rust removed then zinc primed, stone chipped, primed and painted in cellulose - amazingly colour match is perfect with the paint on there!)
Complete replacement of brake pipes at the rear of the car- including the long one that goes the length of the underside (I learnt to make up, cut and flare Kunifer brake pipes for this job).
New front O/s indicatopr lens
New front N/S idicator unit (the old one was corroded and played up just before the test so the garage fitted the replacement.
I also machine wire brushed the front struts and all accessable suspension pieces to remove any rust- then zinc primed and painted in chassis black.
The brakes are great now and the car looks better for having clean shiny red sills.[][]
