RichardLW
The car just about passed its MOT test yesterday. The CO2 reading was very high - .12% with a max of .20% - and the tester could not hold a steady 2500rpm as the revs kept falling away. Any thoughts on this? (BTW it may not be that high in relation to the maximum but this reading was only achieved in the last ten seconds or so and went off the scale again afterwards - its also the highest of any car I ever had).
Also, the inner surface of the rear discs is corroded apparently, although the outer surface is OK. Seems odd to me so, again, any thoughts?
The cross-drilled holes are full of dust and need clearing. High pressure air line (H&S issue?) or drill them clear?
And I guess I now need a trolley jack and a torque wrench for the last job. What make and where from would be much appreciated.
Richard
Richard
