MoT
Fen
Non Member
Mt cab just failed its MoT..... on a brake light bulb. Chuffed. No money to spend on it then... [;)]
If you'd checked the lights b4 you went, you would have had a clean pass.
Then you'd have something to shout about!!
Melv
It was out on Sunday, but I fiddled with it and got it working. It was out again today, I cleaned all the connections and it worked, but not by the time we got to the test station... Must have been a dodgy bulb rather than one that had completely failed. I'll take a pass with a 74p fix any day, though [8|]
I'm sure such bulbs have an in built system which encourages them to blow at pre-MOT moments and the like.
IIRC this is an earlier development of the priority chipset installed in most PC's which allow them to break down at Crittical Requirement Absolute Priority moments.
Well done on passing your MOT, Belinda's Land Rover passed today as well. Can't get rid of that for another Porsche now then.
Looks like we are all due at the same time. My S2 goes in on Friday
My little metro Gti failed miserably two weeks ago so I sold it [8D]. Back to a two car family.
ORIGINAL: Kevin Welch
Nice one Fen,
Though it was slightly damp for the return drive on Sunday.
Definitely not top down weather - I didn't even need Emma's hairstyle concerns to keep my finger off the button. In fact I think the cab has been used almost every day for over a week and I think the last time the top was down was last Wednesday. Let's hope it's dry tomorrow...
Hi Ian,
I had the same call two years ago, and it's a horrible feeling. The good news is that there's no reaosn it should be terminal: if it wasn't even an advisory last year it's unlikely to be a completely rotten car!
You might need to find a local guy who isn't going to see "Porsche" and assume you'll open your wallet. I used a small classic car restorer for mine, to redo what the "recommended" repairer had bodged up for the MOT. [:mad:]
It all depends how far you want to go, but there isn't a car out there that isn't repairable/restorable. If it's mechanically good, then some money thrown at the bodywork is better than taking a risk on another car IMO. Good luck!
+1
I've had this as well, you really need someone who either knows these cars or is used to doing these sort of repairs. Prices vary massively so shop around.
Where abouts are you?
Although it may not be terminal you do need to way up the pros and cons if say £2k will get the car spot on and a few years more use out it, great, if not and there is a list of work it might be worth buying one someone else has already spent the money on!
Whats the engine like?
Hi Ian
Sorry to hear this....my S2 had a bodged repair on the n/s sill when I bought it (only discovered when it started bubbling through later on). FWIW I took it to Specialised Paintwork at Calcot (behind Porsche GB)...they did the sill and the bottoms of both front wings, cut out all rusty metal and welded in new steel sheet. A good repair, still OK several years on. At the time Carl said they were doing 3 or 4 944s a month, so they know what they're doing.
I say repair it... it's not the big drama that some people would have you believe. The outer sill can be in a very bad state before it spreads deep into the structure of the car (take a look at my thread!). I paid £600 to have my local garage (bear in mind this was in London) do a good repair to the nearside and am now replacing the entire offside sill myself.
Hi Ian
The only way to assess is to have a body shop open the area up and see what the damage is.The area at the rear of the sills is now a common problem and if a bodyshop doesn't know the structure of a 944 they may think it is terminal.It is common that from underneath and looking at the suspension mount you see the area behind the circular opening of the mount as badly rusted or holed.This is infact the inner panel and not the mount itself.
My S2 is currently having that area repaired , on both sides while it is in the N/S wwould be a mot fail and the o/s not as bad.The good news for me is the inner sills are perfect and when repaired will be as good as new.The car had a very expensive repair done by a previous owner but all they had done was use filler ! absolute bodge job and rip off.It was 8mm thick in places.
I will post a set of pics from start to finish so the problems can be seen for those interested.
Where are you based , the garage I am using are superb and work on a range of classic cars all the time.
Hope it works out for you.
Nick
I'll be stopping by the shop to have a look and discuss. They've got it opened up to have a look and have suggested that I should see it before making a decision. These guys know their transaxle Porsches - they look after a fair number of them and race them. I've been taking the car there for a couple of years now and do trust them.
I've just been out to Maidenhead to have a look and discuss with the shop. Don't think it's as bad as I'd initially thought. They're estimating 4-5 hours and I'm now leaning towards getting it sorted..
ORIGINAL: robdimond
Hi nick, who are you using? I'd like someone to have a look at mine in the near future, and you'll remember I'm not far from you.
Regards Craig
Hi Craig , I am using Powells of Ripon , they specialise in restoration and are excellent , look at their website and also YCSC site which is their specialist sales business. They know the 944 and Dan Powell who runs the classic car sales business has one he uses every day.
They have been taking photos of the work on mine as it progresses , some of which I will post for interest.
I know the guys as I do some work for them , if you decide to take it to them for an assessment let me know and we can meet up.
Nick
Cheers nick, really helpful thanks, I'll probably take you up on that as two heads better than one, especially where my heads concerned.
