My Boxster 3.2 new in September 2005
- Thread starter lizzyd
Is there any sign of oil leaking, any spotting where you park overnight or any sign of oil under the engine?
If you use an independent Porsche specialist I’m sure they’d be willing to put your car on a lift to look for any sign of an oil leak.
Are you sure you’re not overfilling with oil? What has made you think that oil needs adding?
Some smoke on start up isn’t uncommon and isn’t usually anything to worry about but do you see any sign of smoke in your rear view mirror once the engine has warmed up and you’re driving? Maybe you could get a friend to drive behind you watching for any sign of smoke. PLEASE don’t have an accident whilst looking in the mirror. If bluish smoke is seen whilst driving I suggest you get your car checked out by a Porsche specialist.
It has been running very smoothly - no signs of smoke or oil under the car when in the garage. AS you say, a check with a Porsche specialist probably the best answer.
If you use an independent I recommend that you get them to check the level to ensure that it isn’t over full. If you are anywhere near Yorkshire I can highly recommend Revolution Porsche.
if your engine has used 0.5 litre in 2000 miles it’s probably ok but a Porsche independent will advise you better than me.
Roger
