Eiger
Hi All,
thankfully I took the advice given in my newbie post in the 924 forum and held out for something without a "thunk" in the rear - which is why a sweet 1986 944 Lux is parked on my drive this evening. I had the pleasure of driving it up from Somerset to Southants this afternoon under a glorious blue sky - what a day to bring home my first Porsche. Pics will follow soon.
A few things need doing but it's nothing more than I expected really and the drive up certainly revealed a very solid car mechanically - no thumps, thunks or knocks even when hitting a couple of small B road potholes. I'm very happy about that. It does feel a bit "Rolls Royce" if you know what I mean so that's going to need sorting - new dampers?
The only real downside to my purchase was that the car failed MOT because of a 50p size rust spot behind the stone chip protection on the passenger side sill within 12 inches of the seatbelt.... personally I think the tester was being a bit pedantic as the rest of the sills are solid - the rust is not visible and not even apparent from under the car. But, at least I know exactly what I'm dealing with & the MOT only showed two other items that needed attention:
a) leaking power steering pump (which I hope a tightening of the bolts will cure); SORTED
b) unbalanced braking due to the front OS caliper being a bit sticky (cos the car hasn't seen a lot of use in the last year according to the tester) SORTED
A couple other things that need attention are:
c) the electric windows stopped working after I had opened and closed them a couple of times on the way home (they'd been strong before that and other electrics work - sunroof, mirrors, stereo, wipers, washer); SORTED
d) no heat from the blower - only cool fresh air; SORTED
e) after a couple minutes of working fine the temp gauge goes ballistic and then sits at max (even tho the car doesn't overheat or use water - I topped it up before the journey & checked it on route)
f) the passenger footwell carpet is a bit damp - I haven't pulled the battery out yet but initial inspection doesn't reveal any rust; SORTED
Your sage advice on sorting the above would be greatly appreciated!
Steve
Steve
