My horn sounds after i have locked my car?
- Thread starter Guest
Elliot Davies
When i lock the car with the key fob, the indicators flash and then 5 seconds later the horn beeps twice, in the hand book it says that when the car does this, the bonnet is not closed properly or the centre console is not locked, both have been checked to be closed.
I wonder if anybody has has a similar problem, and the sensor/switch for the bonnet is out of adjustment. Does anybody know where the sensor/switch is located?
John
I have just purchased an "S" and not knowing a great ammount of info about the car found (only sometimes) when I alarm my car, i get 1 quick horn blast, is there a double option for when the roof is down, say click twice on the remote and it does something else?
I will have a look as well, let us know what you find.
Good hunting,
Peter
Black S 18" Classics, sport seats and a Road angel that just got me out of doo doo!!
Elliot Davies
My usual one is the centre cubby hole is open as my elbow hits the button and opens it.
Also read my last post above.........The radios have caused problems so some OPC's removed the alarm wire, easy done if you have the removal keys, maybe yours is connected / loose if you cant find any obvious reason for the beep
ORIGINAL: Peter Watson
Clicking twice disables the internal movement sensor. (This also causes the horn to beep as it is telling you that something - the internal sensor - is not alarmed)
