Steve Brookes
Moderator
Some of you that came to the Curborough bash will know that my car developed an issue with the immobiliser locking on and preventing me from firing up the engine. It was one of those frustrating intermittent electrical faults with no clear path to investigate. I could get the immobiliser to unlock by randomly pressing the fob. There were times when I would think that's it, it will never come off and all of sudden it did! Putting it into a garage didn't seem like the right approach because the random events were never reproducible. I'd already put a new battery on so that eliminated a bad battery from being the problem.
Luckily, on the way back from Curborough fuse #1 blew and while this meant I had no control of the HVAC system, the problems with the immobiliser ceased. I could get it to unlock and start the car every time. If I put a new 25 amp fuse in position 1, the random immobiliser problems came back. Therefore I now knew that I had to find the fault in the HVAC system that was interfering with the immobiliser. I'm not very knowledgeable of electrics but my thought process was that the HVAC system was causing a big current drain as soon as the ignition was turned on.
My first thought was that the blower motor had siezed but taking it off showed that it still turned freely. So then I suspected a siezed front cabin fan. I unplugged each but they had no effect on the immobiliser. I then looked at the final stage regulator (FSR). Here it is plugged in:
So I unplugged it:
The problem with the immobiliser disappeared. It would unlock everytime so I could start the car. With the problem solved I snapped up a used FSR that was on 'buy it now' on ebay and headed off to my trackday with the old one still unplugged. This meant that I only had the slow flow of the rear blower for de-misting so I had to open the window to stop the car steaming up. After an hour so the problem returned so it wasn't the FSR after all! Should have done a test drive and not just tested the effect on my drive [
Now the only thing left to try, was to remove the climate control unit (CCU). That was duly removed and I took the little fan off while I was at it (incase that was the problem with the CCU which I could try later):
While removing the CCU I found the famous 'green radio wire' that is known to cause current drain if it earths on the body. It looked to be pretty well insulated but I taped it up more for good measure (it's not used on my Alpine head unit):
Tests on the drive indicated that with the CCU removed the immobiliser problem was solved [
]. So I went for a long test drive this time. It was bloomin' cold without any heat and the window down to stop the screen misting up. However, this didn't solve the problem either as the stuck immobilser came back when I stopped. [&o]
So at this stage I was still left at the point where with fuse #1 out, all was fine but none of the main HVAC components seem to be at fault. i.e. with fuse #1 in and one of the HVAC components disconnected, the immobiliser problem was still there. Finally, and although I'd not noticed any problems with the rear blower not running, I pulled the rear blower relay (audi part shown in the pic below):
Not only did that solve my immobiliser problem but replacing it with the oil cooler relay (identical part) meant that could have both the HVAC system working and a car that starts! Now just need to go and get a new relay to put in the oil cooler slot [
]. In fact, I'll get two new ones while I'm at it [
So I unplugged it:
