my wheel swap before front and after rear...
- Thread starter cococola
Chrishazle
edh
modernclassic said:I think those look better than the cookies (which age the car), but too modern for that car. D90's or dials or CS or Cup1 would work better. Are those not wheels from a Boxster/996?
Huh?
Teledials were an option
D90, CS, Cup 1 also "too modern" and strictly speaking not suitable, wrong offset so need spacers, as do Cup 2's (unless aftermarket low offset Cup 1 or 2 replicas)
D90 & CS were std/options for later 944's
Cup 1 (964-era) & Cup 2 (993-era) were options for 968 (not 996) - equally suitable (or unsuitable) for an early 944
944 man
Definitely don't sell the Cookie Cutters, as others have said. The days of them only being worth their weight in aluminium are long since passed. Also, presuming that the Cups2s are original and fitted using spacers, then I wouldn't sell those either, if you swap back. If theyre early offset copies then I wouldn't be bothered, but I always keep original wheels.
Chrishazle
Cup1's to 93 Cup2's 94- my
All Coupes and Cabs had 16" Cup 1's as std.
pre '94 Coupe's could have 17" Cup 1's as an option, and would have if upgraded to sports suspension (M030).
17" Cup 1's on pre-94 CS's
Post 93/94my Sport and CS's all had Cup 2's
Info courtesy of Porsche968uk.
Craigybaby
Craigybaby
944 man
Chrishazle said:Cup 1's and Cup 2's were standard on 968's, not options, depending on MY and model.
Cup1's to 93 Cup2's 94- my All Coupes and Cabs had 16" Cup 1's as std.pre '94 Coupe's could have 17" Cup 1's as an option, and would have if upgraded to sports suspension (M030).17" Cup 1's on pre-94 CS's
Cups were 16" in diameter. You have pictured Cup1 and Cup2s which were 17" in diameter. 16" 7" & 8" Cups were standard on full-fat 968s, with Cup1s and then Cup2s being the 'option'.
