Need a broken or surplus headlamp unit
nfearn
Folks - I have an interesting and I hope unusual problem with both of my headlamps.
As you will be aware, the headlamp aim adjustment is done from inside the boot area using a hexagon wrench (Allen key). When you're turning the component with the key, what's actually turning is a cast metal bevel gear (think gear wheel with a 45 degree angle on it) which meshes with a similar bevel gear inside the headlamp.
This second bevel gear is a one-piece plastic moulding which also incorporates an M6 threaded stud. It is this stud which the reflector moves on to change its position and hence alter the aim of the beam.
In fact, there are two of these bevel gear assemblies in each headlamp - one for up and down and one for side to side movement.
On my car, both of the up and down plastic bevel gear / stud mouldings have had their threads partially stripped and the height of the beam can no longer be adjusted. No idea how this happened - probably ham-fistedness at the MOT place at some time or another.
Anyway, I need to either repair (not easy...) or source replacements for these two plastic bevel gear / stud mouldings.
Does anyone have an old headlamp unit I could cannibalise them from or have any ideas as to where I could obtain such a thing at reasonable cost?
All suggestions gratefully considered.
what about from one of the Porsche breakers, where the lamps have been destroyed but the adjusters are probably in one piece ?
I've tried one of them who said they couldn't supply these. There is at least one more I could try though.
This would of course be my preferred route, but I have a couple of alternative plans on stand-by, just in case.
Hi
How much would you like for them? If you can PM me your email address / other details we can continue the discussion offline.
regards
Nick
I understand that the forum email and PM system hasn't been working. I am still interested in the headlamps though.
regards
Nick
It's not working through the forum, apparently. That's why you haven't received any emails...work in progress.
See the big red notice on the top of the forum home page...
"We are sorry, but due to technical issues we are unable to determine when we can fix Email, PM and Subscription Problems. Please accept our apologies".
