tartan_rob
I have had this problem with the car since Dec '14 (I think); I did some welding over x-mas '14 and forgot to dissconnect the battery - this may or may not be resonsible for the issues...
The car was running okay before welding but the next time I tried starting her was Feb '15, she was lumpy, hard to start, struggling to idle, struggling to rev etc before dying. A Porsche trained mechanic mate has been over her with a fine toothcomb but we can't find anything wrong. In the absence of obvious faults we sent the ECU off to BBA-REMAN who confirmed it was faulty. They also confirmed that they were unable to replace the failed component or to bodge a fix.
golfprorich has kindly provided me with the loan of a known good ECU in order to see if that was the issue. The car is better than before but still lumpy, very poor running, struggles to idle or rev and there is no way you could drive her, I can't get her to run long enough to engage a gear.
I am really at the stage of having her cut up unless I can get her going. Does anyone have any advice or support they can offer or even someone in Wiltshire know where I can take her to try and get fixed?
I have committed a lot of time to get her into the shape she is and don't want to let the angle grinder get the better of me.
Thanks in advance,
Rob
Thanks in advance,
Rob
