Clewsey
Hello all, For those of you very mechanically minded on this forum I'd really value your thoughts and advice on an escalating problem with my 2002 (Facelift) 986 S and to give me your thoughts on my theory. I am not that mechanically minded but have a logical brain at least!
Some background/context:
I've experienced three issues (latest one today) during track sessions ONLY. The car has never experienced any kind of issue with normal road-use (hard or sedate driving). The only thing commonly observed any time has been a very small amount of smoke at initial start-up, then nothing subsequently. Car runs nice and smooth.
Result of first track outing - very small oil leak, cause was an engine crankcase plug/seal. No oil leak prior to track session (check garage floor each drive). Whilst quite bizarre, the plug/seal was replaced, oil cleaned up etc. Further road driving fine and no oil/coolant loss etc. All good again.
Result of 2nd track outing - as above. Exact plug/seal again popped! Specialist ran a series of cylinder leakage tests and all showed good consistent results (3 tests). The AOS was checked and whist the specialist was going to replace it out of the fact these are a typical weak-spot, it was confirmed this looked fine and so wasn't replaced. The concern here (and was discussed after the first instance) was a possible build up of pressure inside the engine and as it popped the exact same one, a real possibility as this shouldn't happen! The specialist used some gasket sealant on the plug to keep it in place.
Car driven hard by both me and the specialist and all fine. Some spirited drives later, no oil leaks and all smooth running. As I'm doing Spa later this year the only way I was going to test it was to take it back on track to see if the problem would come back. Well, it did but in a very different fashion.
Today, after about 5 laps (all fine at this point) I exited a corner and accelerated hard. On doing so, an almighty plume of WHITE smoke filled my rear view mirror, CEL came up (flashing yellow) and at which point I backed off and parked up off circuit. Smoke exiting exhaust.
Things to note. Engine hadn't blown, no rough running pre or post incident. No overheating, no oil loss registered on gauge OR visually dropped on ground. Idling was as smooth as under normal conditions. Track support who was with me were as bemused as I was given the fact the car was still sounding fine. On checking the oil filler cap, there was a lot of pressure/vacuum going on. I drove it extremely lightly 30-50mph for 3 miles and after a few miles, no smoke. The car was recovered home where even after a cold start, not too much smoke was found. The other thing to point out is that my CEL light came on at the initial incident today but on repeated starts doesn't display the CEL message....
My logical theory:
The symptoms of the HUGE white smoke points to an AOS failure. A high build up of pressure (as before) wasn't able to pop the plug/seal because it was fixed in place and therefore found the next weak link as pressure needs to escape after-all. I've read all the usual posts of AOS failure and the symptoms I've mentioned previously all appear. My Porsche specialist wants to give me an explanation but at the moment is quite frustrated. His next move would be to use a scope to go and have a deeper look. However, the car just doesn't show any signs of a major engine issue (other than the smoke) and even that isn't too bad on returning home today.
Looking at a thread on pelican parts, not only did it discuss the AOS failure symptoms at length but then also mentioned that these type of failures are caused by other engine issues (positive crankcase ventilation valve) or PVC getting clogged or broken causing excessive high pressure to build in the engine and then ultimately breaking the AOS. This is one of paragraph of interest from this post:
http://www.pelicanparts.com/techarticles/Boxster_Tech/09-ENGINE-Air_Oil_Separator/09-ENGINE-Air_Oil_Separator.htm
"Followup from the Pelican Staff: The air oil separator is a an emissions control unit whose purpose is to separate fuel vapors from the crankcase and funnel them back into the intake. These units fail over time when the diaphragm inside gets old and breaks. They can also be caused fail prematurely by other components on the engine failing, most noticeably the positive crankcase ventilation valve (PVC). If the ventilation valve is clogged or broken then the pressure / vacuum levels inside of the engine may become very high, and that puts a lot of stress on the air oil separator diaphragm. Typically when people have a air/oil separator failure problem, and it keeps happening again and again, it's often related to the PVC valve. I did a close look at this first. - Wayne at Pelican Parts"
Obviously there is no other explanation that the high pressure causing the same plug to pop each time but I think the paragraph above could be a real possibility as no doubt there is excessive pressure happening. I don't know if the specialist has looked at the PVC but it seems very possible. I don't know how common these break.
If you have any thoughts or other alternative suggestions, I'd really appreciate them. Until the root problem is found, it's hard to make a warranty claim... I just can't now risk doing any more track sessions until this is fixed. It's also costing me a lot of money each time and I'm now getting earache....... say no more.
Thanks very much for any help and sorry for the long post!
Cheers,
Simon
My logical theory:
Cheers,
Simon
