scam75
Well-known member
Afternoon All
I am suffering from understeer, a lot worse in the wet currently. I run a bit of negative camber and the front ARB is stiffened with poly bushes and triangular ARB supports. Car is lowered about 60mm also. Is this to be expected? Turn in is very sharp and understeer is exagerated when already cornering and applying more steering.
I currently have pretty well worn Toyo T-1S's on the front which are getting a but tracked on the inside. Anyway I have just ordered a set of Uniroyal Rainsport 3's to chuck on. This tyre seems to be pretty soft and seems to give excellent wet and dry grip, only trade off being they wear quite quick.
I assume I will only get 5k miles out them maybe however I am hoping they make a difference to my current understeer issue.
Any thoughts?
Stuart
Any thoughts?
Stuart
