TopCarrera
Please can anybody help?
Had suspension on my car stiffened and lowered about six months ago. After a couple of track days and about 500 miles later the nearside rear arch is just rubbing the upper part of the outer sidewall of the tyre when the car is at maximum acceleration in the lower three ratios (i.e. squatting under power).
I am running about 1 deg negative camber on the front and 1.5 deg negative on the rear. I am on Fuchs 7s&8s with 205/55s & 225/50s Bridgestone S02s. Have been advised that adding another 0.25 to 0.5 degrees of negative camber will enough to stop the rubbing. Is this reasonable?
I will roll the arches if I have to but would prefer to leave alone and rely on geometry if I can. Is wheelarch lip rolling straightforward for a garage with a recent bodyshop to do as a quick job? Is it easy to do as a home job? The lips on the front arches are much bigger than the rears; will rolling romove the profile of this lip completely on the front of the car?
