New 944 Owner
- Thread starter Hairyarse
mrsfordy3.2
MikeTeesside
It's a 944 NA 2.5L Lux, made in 1988. I have a 1967 Triumph GT6 as my weekend/show car, the 944 will be my daily and will live on the street. I wish I had a double garage to protect both of these wonderful vehicles. Apparently it's lived outside most of its life anyway with very little rust, little bit of bubbling on the nearside front wing that I'll tackle in time but that's it for rust. The sills have been fixed and welded up already with new steel so I don't have to worry about them. The belts were done by the previous owner recently. It has Turbo Twist (I think that's what they're called?) alloys and very wide tyres which I like a lot. It has side skirts which are not original, but again I like them a lot. It has a non-standard exhaust which I do NOT like a lot.. I will put a proper one on later that doesn't fart like a chav-spec corsa. Urgh.
The bad points:
* The oil pressure gauge always shows 5 regardless of the actual pressure.. this can't be normal? Knackered gauge most likely.
* The voltmeter sometimes works and sometimes doesn't. Whenever it feels like it. Same gauge as the oil pressure.
* The drivers door does not centrally lock but the motor works, I'm aware of how to fix it and already ordered the plastic rod.
* The drivers door window does not work, it's the switch and I've already ordered a new one.
* The clock is knackered. I'm aware of how to fix it and will do so.
* It has no stereo.
* The stereo wiring has been chopped to bits, but I'm electrically trained and it'll be fun restoring it.
* The door speakers are broken. New speakers required.
* It has a horrible garish aftermarket gear knob which buzzes and rattles like crazy. Pretty sure it's missing the rubber gaiter or it's simply not sitting securely, it stops if I grab the top firmly.
The good points:
* Mechanically it's sound as a pound on a merry-go-round. No gearbox issues. No engine issues. Belts done. No leaks.
* The previous owner gave me tons of spares including some rather expensive switches. Go go gadget eBay!
* Most of the "work" needing doing to it is purely cosmetic.
* It has pretty good MPG for a sports car!
* The handling is the best I've felt in any car. Ever.
* The electric seats work flawlessly.
* It has the JMG Short Shift Kit fitted by the previous owner.
All in all, I absolutely love the car and look forward to driving it every time I open the door and turn the key.
I swapped it for an obscure 1990's Honda. No money changed hands. Very happy. [
MikeTeesside
andy watson
Moderator
MikeTeesside
I was worried too, but the guy sent me a full picture documentation of the work he did on them. Before he did the work they were awful, with holes you could put your hand through! Talking about the outer sills mind you, the inners are fine. He cut away all the bad metal and replaced it with good metal, coating the inside with waxoyl and the outside with stonechip. He's also a long time member of another forum I go to and is well trusted, I would be very surprised indeed if the sills were bad, he's a very good and experienced welder.ORIGINAL: 944 man Id be worried about what is under the aftermarket sills.
