Sandspider
So, I thought I'd give my 944 her pre-winter service and checkover.
All went well, and I was feeling fairly smug - no stripped screw heads on the air box, spark plugs beautifully simple to change, washer jet nozzles adjusted just so... Then I went to start her up for a spin to warm the oil before changing that. And she would barely turn over. ****. It seems my battery is flat. Not entirely surprising, as it is a good age battery (10 years or more) and it's getting cold here. (A multimeter says the battery is putting out 11.68 volts, which doesn't seem too low, but I suppose that's with no load on it...) Anyway, I think I need a new battery. The battery in there is type 067, 66AH and 530A SAE. As this battery has served me so well, I assume the same again would be appropriate. Any recommendations on make? I've been fitting Exide Premium batteries recently (after a recommendation for another make of car), and they seem to have done well. CP4L suggest an 075 battery for my car, rather than a 067. Is the 075 possibly a modern replacement for the older 067s? Will go and measure to check the size is the same.
Is battery replacement a simple job? I can only see one clamp holding the battery down, though the bolt head looks to have a strange fitment. Also, might my immobiliser cause problems after the battery is disconnected and the new one connected? (Aftermarket immobiliser, Autowatch PPI with the little key ring transponder to touch to the sensor in the car).
Many thanks for any suggestions.
