Is anyone having a major problem with their new Cayenne S.
Bought new model Cayenne S in October. In January the car started suffering with reduced power and stuttering under exceleration. (as if it was running on bad fuel). Car went into Local dealer to find fault. After 4 weeks!!! they thought they had solved the problem. The manifolds were overheating which was reducing the power. Eventually concluded it was the PASM control unit on the traction control that was sending a message to the engine that traction had been lost so the engine was retarding. After fixing the problem and test driving the car for 2 days, it was returned to me fixed!! one day later back into porsche. new fault. bumping sensation from the rear. Feeling like the ABS brakes were being applying as you accelerated. Feeling like you were driving down a bumpy road or running over rumble strips. Car has now been in for a further 5 weeks with the Porsche Dealer.
Has anyone else having the same issue.
