New Exhaust
I need a new box on the Lux and have a few questions as I don't really know anything about them.
1. Could I fit a stainless box and pipe as this to the existing exhaust - see the first one below from Design 911
http://design911-px.rtrk.co.uk/fu/pt63_398_-cma81-cmo123-ct304/Porsche/Porsche-944-1982-91/944-2-5L-1982-87/Exhausts---Catalyst---Manifolds/Silencers---Mufflers/
2. Is the above Dansk exhaust a good one to get?
3. Is it something I could do myself, if so any tips? I am quite handy with things and imagine its quite simple but you never know.
4. How high would I have to get the car up to do it? Would axle stands suffice?
5. How do you join the two sections of the exhaust? Is there a sealant/gasket to use?
Ta
Spence
Are you talking about the rear box or centre box? The rear box is easy and I did mine with some axle stands lifting the rear of the car about a foor off the deck. Three bolts (4 on an S2) hold the rear box to the front box, with a metal seal in between, and two bolts hold the back of the rear box to the rubber hangers under the car. Simples I think the front Dansk needs the pipe to be cut so a slip joint will fit over it - I'm not positive though
