New gt3 Clutch....!
carreraboy
Just picked up the Clubsport with it's brand spanking new "designer" lightweight clutch...which has a stronger GT3 Pressure Plate....must say the gear change is now smooth as silk and the clutch is lighter than my old lightweight.......[:D]
Thought it was the clutch pressure plate fitted with a standard (non CS sintered) RS clutch disc.
Certainly seems to make a difference Des, didn't have to slow down that much in a 1.4 diesel for you to nearly keep up [:D]
Correct Paul, the part numbers on the invoice thus seem to be on the wrong part...
964 116 028 90 = ?
996 116 015 32 = ?
944 116 080 01 = ?
With those part nos, 2 are clearly water cooled, you are obviously defecting and building a kettle bit by bit [:D]
...on the invoice
964 part number = pressure plate
996 part number = Center plate
944 part = release bearing.....
Must be a Motorsport clutch plate - kettle part #, because the comfort is 996 116 015 00 and the clubsport is 996 116 015 30
Interestingly the Porsche PET lists my car as 911 carrera RS Clubsport M003[:-]
Anal Tim
