Dan944t
hi guys
As some may remember I have had to do a full engine rebuild on my 944 turbo due to a spilt bore, and I have finally managed to start and am 4.5 days in, however I have a couple of question one being I’m unsure the correct way to install new head studs?
in this I mean a couple of things:
the studs have two lengths of thread on iether ends as you will see from the photos added.
Now my questions are :
•do I lock tight the studs in?
•do I thread the shorter threaded end into the short block? Or do I thread the longer side down with enough length to secure my head with maybe 3+mm protruding ?
•do I bottom out thenturn back half turn ?
i have calculated with my gasket I’m using I will need 72mm stud + any extra length that will protrude above the torqued nut, so by installing the studs into the block with the shorter length of thread it would seem the right way to go as you will see from the photos this gives decent amount of excess length after the nut will have been torqued down. However the other way round with the longer length of stud screwed into the block is not long enough although if I bottom out and then turn back 3 revolutions as picture shows it give enough length on top as photo shows.
i was going to screw the longer end in . bottom out then back out touch and locktite with 542 but as this is my first full rebuild I wanted to ask some advise first to be in safe side.
many thanks
Daniel ??
https://imgur.com/a/PaTx4vm
https://imgur.com/a/3PKqSlJ
https://imgur.com/a/eOmMXa1
Ps I noticed also that the shorter threaded end is rounded at the top and the longer end is not finished so nice which would suggest that the short end shoukd be at the top but as you will see in the photos I installed the head with gasket and hand tightened , and you can see that the stud doesn’t quite make it through the nut, as serdi removes the old studs for me I didnt get to measure and look at the old ones.
many thanks
Daniel ??
