New MOT requirements
Cater_Racer
As the 993 came with airbags installed, the new MOT infers a fail if you've an aftermarket steering wheel without an airbag.
There's quite a bit on piston heads on this. Consensus seems to be that removing the airbag light also removes the need for the MOT guy to check for an airbag.[8|]
Suppose it's like he can't check your spare wheel if it's not with the car either[;)].
ORIGINAL: pse_SC
The MOT does not test the spare wheel although 'The vehicle presenter should be informed when it is noticed that there is a defective tyre on a spare wheel' - quote from the MOT Tester's Manual.
