New owner, niggly problem
Hi, i've just bought a 1978 911 sc absolutely stunning car. I've found that the steering column has a bit of free play. I was wondering if this was common on these cars and if it's a quick fix. If so how would i go about repairing this.
Alastair
Hi Alastair, welcome along.
Do you mean free play as in the shaft moves in the column, so your steering wheel moves up and down, or you have play between turning the steering wheel and the wheels responding, like wear in a column U/J or something?
Column bushes would cause the former and are a common problem on older cars, there is a Pelican thread here which explains how to sort it.
John,
Thanks very much for that, it's the steering column that is loose, so it sounds like the it is just a bush that is required. I'll have a play around with it and see how i get on, thanks for that link.
regards
Alastair
[FONT=verdana,geneva"]Hi Alastair,[FONT=verdana,geneva"][FONT=verdana,geneva"] [FONT=verdana,geneva"][FONT=verdana,geneva"]Had the same probem with the steering, the sleeve you need (if you have the same problem as i did) can be bought at www.design911.co.uk[FONT=verdana,geneva"][FONT=verdana,geneva"] [FONT=verdana,geneva"][FONT=verdana,geneva"]Click on special offers from the menu, then special offers from the sub menu, about half was down the page of offers there is a steering column sleeve, this should solve the problem, took me about 20 mins to fix.[FONT=verdana,geneva"]
