New owner question...
- Thread starter mrsimpson
Gordon Attar
Steve Brookes
Moderator
http://www.964uk.com/html/Spec%20-%20Engine%2036na.htm
62M----- is the right code for the engine serial number. That code is a 1991 model year engine. As you can't find it on the sticker, check it against the number on the V5 as mentioned above.
p.s. Well done for finding the engine number...even with Rob's instructions above, many still can't find it on the engine, mostly because the air con is in the way. []
Steve Brookes
Moderator
ORIGINAL: mrsimpson
Thanks Steve, where would I find it on the sticker? Thanks for all the advice guys it's very kind of you all.
From the top you should have chassis number then engine type (you've already found the M64/--) and then engine number and gearbox number (next to each other) in small numbers/letters underneath. I can't absolutely confirm this because mine is one of those rebel sticker-less ones that should be avoided like the plague!
I should have added that the engine number itself is not on the VIN sheet, its only the engine type and year, M6401 being the type, 62M being 6 cylinder normally aspirated built in 1991. The actual number of the engine the car was built with is I believe available only from Porsche.
Rob
Steve Brookes
Moderator
As Rob says, for peace of mind you can get a letter of origin. Contact Ann Burnham at Porsche Cars Great Britain Ltd (0118 9191744). It costs about £60 IIRC. I decided to get one seeing as the stickers on mine went AWOL before I bought it.
