New Porsche Boxster 987 - Couple of problems....
- Thread starter muzzy1
Solution 2) check the fuses. For my Boxster (MY2006), the horn, rear spoiler and rear boot release is on the same fuse A3. No mention as far as I could see of what fuse the front boot release is on but probably worth starting with that. Top row of fuses third from the left - 15A fuse required.
But I did remove the panel/unit with the Spoiler and PSM buttons (below the Climate Control unit), and there isn't actually any cables plugged into the socket behind Spoiler button whereas there are cables plugged into behind the PSM button (which is working)......
I'm guessing this is why the spoiler button isn't working. Any ideas?
Edit: I am just going to check the wiring diagram as I can't recall if all the sockets should have plugs on a Boxster.
Do you just have PSM and Spoiler Buttons or do you have any others?
ORIGINAL: muzzy1
I'm in London, UK. So is that definitely the problem? And I'm guessing thats something i can't do or check myself? Thanks.
If you are in the London area you are in luck as I and a couple of other guys have their own Porsche Tester.
I live near Denham if that is good for you, or you could drop in the Ace Cafe meet this Monday and I will bring the tester with me.
