NEW SWITCH FOUND
ray stobbs
hi i was cleaning the inside of my 964 c2 yesterday and found a rocker switch on the drivers side of the center consul on the side looks like a factory fit very neat in the carpet but can not find any ref in the owners manuel any thougths i think it might be an immobilziser switch [:)]
I have one on my Cabriolet which turns off the sonic sensors on the burglar alarm when you leave it parked with the hood down.
i think you might be right as when ive pressed it the car still start s with the imobelizer keymust be factory fit alarm system regards ray
ORIGINAL: Dekker
I believe this to be the case, so that you can e.g. leave the sunroof open on a hot day. I also thought it had something to do with switching off the 'total closure' but I'm not sure on that one.
no its manuel thanks so still no wiser nothing seems to happen when pressed im convinced there is no wires behind will have to have a look thanks
yes it's part of the factory alarm system. I have the switch on my turbo but I don't think it does anything anymore as my car has a newer after market system fitted.
I have one on my Targa, which is located next to the overide key socket, for when the blipper stops working.
So the theory about the switching the interior sensors off is very likely.
There is one in our 964-I was reliably informed that it was indeed to isolate the cabin sensors so that windows,sunroof etc could be left slightly open or an animal left inside(which would then need ventilation).I have never used it.
The sensors are supposed to be within the rear seat panel but I have not found them yet. [&o]
