Newbie Help
- Thread starter xenon
Diver944
http://www.porscheclubgbforum.com/tm.asp?m=38842
xenon
Is it reasonable, do you think, to use a car like this as a daily driver? What are running costs like? I doubt they're any worse than my current BMW 325i which drinks like a Lib-Dem leader and appreciates a change of 0w-30 every 3000 miles....
Thanks again!
sawood12
At the end of the day the 944 is just a car like any other and should be treated like one. There is no special treatment of the car required - oil change annually or 12k miles (6 months or 6k miles for a turbo), observe the timing belt change interval as diligently as if your life depended upon it and other than that just drive it and enjoy it!!
xenon
Diver944
There is a cambelt and balance shaft belt at the front of the engine behind plastic covers.
There is also a camchain that links the two camshafts. This is inside the head and is not on any scheduled inspection list from Porsche so you need to make sure it has been looked after by someone who know's this.
A good rule of thumb is to change the belts every three years or 36k miles and change the camchain and tensioner slipper every 50k miles
