Tim
You are right that the grey's do wear more than the yellow's and if you read my first post, you will see I have discussed this and given the cost of the disks. James also said he wasn't too fussed over cost and I think that from my experieneces with 2 cars running the grey, this really isn't an issue.
As for speaking to somebody who has had hands on experience and has tried a variety of pads, that is why I have posted. I have used most of the Pagid range on both road and track cars and on many different makes of car. I ahve also done signifcant miles and some hard driving on the greys on my RS so feel well qualified to comment.
When looking at the key factors used in choosing a pad, the greys stack up well.
1. They have the best friction coefficient of all Pagid pads. Only the DS3000 pads are better and that is only when cold but they squeal worse than any other pad!
2. Do they give good brake modulation and the answer is yes, as good as most performance pads and there is no sudden grappiness or late release.Modulation isn't as good as, for instance, Pagid blues which arepopular in rally situations where modulation is a big issue due to different surfaces that mean your really need to "feel" your way with your braking or you will too easily lock up.
3. Do they unbalance the car and here the answer is no. In fact, I think they balance the car better than OEM pads and they leave the car feeling very stable and set up.
4. Are they too noisy? This is subjective and depends on what you find acceptable but they are no worse than most other Pagid pads and better than some.
5. Longevity of pad and disk. Again this depends on what you personally believe is acceptable. Ultimately, you get what you pay for but as a % of running costs, replacing disks is not expensive.
Overall, I personally find little reason to use any other pad in the Porsche. Changing to them was like changing the whole brake system which is something I know people have done.
