Chris Goodman
Hi everyone - just transferred from white 911SC to black 944 Turbo SE!
Some (probably) dumb questions:
1) The brakes don't seem very effective - or at least they require a heavy push to be effective - is this typical?? I've read other posts about red calipers on SE's but mine are black - are they original?
2) The furthest left switch in the row infront of the gear lever doesn't seem to do anything, has no 'picture' on it, and in my driver's manual the switches are shown in a different order - is it a 'blank' or is it doing something I just haven't noticed?
3) How do I cure the rattle from the hatchback over rough surfaces? I've tried adjusting the length of the conical-ended bolts but if they are long enough to let the hatchback lock closed then I get the rattle.
4) There is a vertical metal pipe (looks like a breather) at the left rear of the engine blanked off with duct tape(!) - what is it and what was there before the duct tape??
5) The 944 seems so quick and has such a good driving position - why does anyone buy a 911?
Chris
Chris
