jayandrews
hi guys,im very new to this scene having only just bought a h reg 944 turbo for some weekend fun/light restoration and maybe if it will take it some track use.
the car i have got has very good service history and has only done about 8k miles in the last 10 years.had a freshen up at hartech and also recently serviced at 911 in warrington.
what i have noticed is when driving it the temp gauge goes higher than i would ideally expect it to-up to about two-thirds of the way up.doesnt really go any higher and tends to go down a bit when driving.also if you put the heater on and fain inside car it helps it drop to about halfway.the rad cooling fans are coming in and i can hear the electric water pump working.
anyone else with a 944 turbo who can tell me what temp their car runs on the gauge.i was tempted to either
fit aftermarket gauge/fit new fan switch/fit new temp sender/wire fans up to a switch.
its running a bit over standard with a promax stage 1 kit,heyward and scott exhaust.love its performance and its looks-so much in fact its currently being stripped for full repaint.
thanks in advance
jason
thanks in advance
jason
