Nigel - Double-beep on unlocking
A double-beep means there is a system fault. In most cases it is a sticky or broken microswitch in one of the door lock mechanisms. The best bet is to get a diagnostic check, which will show the cause in the fault memory, and in the 'events' page, of the alarm module.
i now have the same double beep on unlocking and the driver side door glass drop/raise is faulty
i foolishly used a 12v tyre inflator whilst the engine wasnt running and it drew too much power
and electrics went all off - only lasting fault i think is described above
anything i can easily check or fix myself ?
thanks
well the fault has become intermittent along with the window drop on driver side not working properly - guessing it is a sticky sensor
